NI TestStand
how to get container from teststand
Hi all,
I have a StationGlobal in Teststand. It is a Container of two strings and a number (custom data type). I want to manipulate these values in LabView, but I could not figure out how to pass this container to LabView. I think through property nodes/methods/ActiveX controls, but the method is unknown for me.
If I create a cluster in LV to pass it to Teststand, that´s easy, but the other way?
I appriciate any help.
(3,535 Views)
You can do this via the ActiveX API in LabVIEW. Attached you can find an example and two screenshots (one of the VI [fot the case you don´t have LV 8.20]and one of the TestStand Station Global, which you would have to create, if you want to test the example).
(3,518 Views)
Forgot one attachment.
(3,516 Views)
