NI TestStand
how to pass a single character to dll (as a parameter)
How do pass a single character to dll (as a parameter). This is a third party dll that i am unable to change.
e.g.: int functionName(char* process, char myChar);
(3,598 Views)
Did you try passing it as a U8 instead of a string?
Matthew
(3,592 Views)
My apoligies, I am trying to pass a char from Teststand. Passing as a char is not one of the Category
 I tried sending (for example) : Locals.myChar[0].  Which is acceptable in C++, but gives me an error via Teststand.
(3,586 Views)
Try passing Asc(Locals.myChar[0]) with the parameter category set to Numeric and the Type set to Unsigned 8-bit Integer.
(3,583 Views)
James / Matthew,  with some playing around, this was exactly what I needed. Thanks for the explanation James...
(3,570 Views)
Just for the record, if Locals.myChar was a string instead of a numeric array, then you would instead need Asc(Mid(Locals.myChar, 0, 1))
Array subscript syntax would be nice for strings. I'll enter a suggestion for it.
(3,561 Views)
