NI TestStand
how to pass an object between C# and TestStand?
how do I extend below notification example to pass an object between C# and TestStand?
https://forums.ni.com/t5/Example-Code/TestStand-Notification-Cross-Process-Example-in-C/ta-p/3961781...
Is it possible to pass an object between C and TestStand as well?
Thanks.
(2,152 Views)
Hello JTPI
Here's a forum which describes how to call methods from dotnet assemblies:
https://forums.ni.com/t5/NI-TestStand/How-to-instantiate-a-net-assembly-after-loading-a-sequence/td-...
You can use the C/C++ adapter to communicate TestStand with C:
https://www.ni.com/docs/en-US/bundle/teststand/page/c-c-dll-adapter.html
(2,111 Views)
