NI TestStand
how to use setarraybounds for resize 1 dimension of a 2D array?
Hello:
    I use Teststand2013,
SetArrayBounds( FileGlobals.Drt_Step_Data_Filt, "[0][1]" , "[3][3340]") to set bounds of the 2D array "FileGlobals.Drt_Step_Data_Filt".
when I check in the "Watch View" the bounds is in what i want [0..3][1..3340],
but after check the dimension 0-->FileGlobals.Drt_Step_Data_Filt[0], the bound is [0..3339] not [1..3340]
and SetArrayBounds( FileGlobals.Drt_Step_Data_Filt[0], "[1]" , "[3340]") is not work.
what can i do to change 1 dimension size of a multi dimension array?
thanks a lot!
(4,379 Views)
The run time data in Watch view as below:
(4,372 Views)
Accepted by johnnnywang
Hi johnnnywang,
When you look at an array subset in TestStand, it will always be 0 indexed. If you want to be able to set the bounds on the array subset, you will need to assign it as the value of a new variable. For example:
Step 1:
Step 2:
FileGlobals.Drt_Step_Data_Filt_Subset = FileGlobals.Drt_Step_Data_Filt[0], SetArrayBounds(FileGlobals.Drt_Step_Data_Filt_Subset, "[1]","[3340]")
This way the resulting FileGlobals.Drt_Step_Data_Filt_Subset will be 1 indexed.
 I hope that helps!
Steven Gloor
Staff Customer Engineer - CTA, CLD
(4,343 Views)
Got it, thank you very much!
(4,333 Views)
