Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
i want to run one vi in teststand sequence only one time just the first round,and the vi willnot run in the later, how to realize it ? [
walter.shao
Member
03-16-2005
07:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
THANKS
0
Kudos
Message
1
of 3
(3,048 Views)
Reply
Re: i want to run one vi in teststand sequence only one time just the first round,and the vi willnot run in the later, how to realize it ? [
RayFarmer
Trusted Enthusiast
03-16-2005
07:19 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You could make use of the SequenceFileLoad sequence. This sequence is called only once, that is when the sequencefile is first loaded.
Regards
Ray Farmer
Regards
Ray Farmer
1
Kudo
Message
2
of 3
(3,044 Views)
Reply
Bob Balch
Member
03-18-2005
04:21 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You could set a Station Global or a sequence global in the vi and use a precondition in the sequence call to check it.
0
Kudos
Message
3
of 3
(3,025 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
