NI TestStand
i want to run one vi in teststand sequence only one time just the first round,and the vi willnot run in the later, how to realize it ? [
You could make use of the SequenceFileLoad sequence. This sequence is called only once, that is when the sequencefile is first loaded.
Regards
Ray Farmer
Regards
Ray Farmer
(3,119 Views)
You could set a Station Global or a sequence global in the vi and use a precondition in the sequence call to check it.
(3,100 Views)
