NI TestStand
import/export properties of multiple numeric limit steps
Hello
I have a question to the property loader and the import/export tool in TestStand 3.5.
When I want to export the limits of a sequence with multiple numeric steps with the import/export tool, I press the Limits button to include the limits into the 'selected' field of the properties tab. But for the multiple numeric step the limits are included not for all indices but only once with an question mark instead of an index (Result.Measurement[?].Limits.Low, Result.Measurement[?].Limits.High, Result.Measurement[?].Limits.Comp).
The property loader step acts the same way.
What can I do ?
Olli
(3,494 Views)
Hi Olli,
For the multiple numeric limit test, you will need to individually specify which numeric limits you want to export. Lets suppose you have 3 sets of limits for your multiple numeric limit test. If you wanted to export the first set, you would use the syntax
Step.Result.Measurement[0].Limits.Low
Step.Result.Measurement[0].Limits.High
You will need to do this for each set of limits you have in your array. Simply replace the "?" with the index of the element in the array.
Hope this helps!
Best Regards,
Jonathan N.
(3,474 Views)
