NI TestStand
"Pause" showing the inner sequence
Hi
if i enable onthefly report in test. when i press pause button during execution the SequenceView control shows the Processmodelpostresultlistentry(It contains the steps -Logresult, Processstep result callback, Discard result) sequence instead showing the mainsquece paused step. how can i avoid it. i want to show only my testsequence(steps) not the teststand sequences(steps)
Thanks and Reagards,
Srini
(4,148 Views)
Hi Srini,
It seems that this behavior is possibly resulted from the Station Options >> Execution Tracing settings. Try unchecking all the options and see if you still see the same behavior. We have not been able to reproduce this behavior back to back but sometimes when checking the various station options. Also, let me know which options you do have set and what steps you are going through to produce the behavior. Thanks
Hope this helps!
Best Regards,
Jonathan N.
(4,121 Views)
Hi Jonathan ,
These options when enabled result in the behaviour said by srini :
1) Enable Configure > Report Option > On The Fly Reporting
2) Enable Station Options >> Execution Tracing and choose only Allow Tracing with Setup and Cleanup
Please calrify on how can the behaviour be stopped even when these options are enabled.
Thanks and Regards,
MadhuSri
(4,108 Views)
Hi MadhuSri,
I am not sure what language you are working in, but to fix your issue you will need to create an event callback for the Break command that is generated by the ExecutionView Manager. The data that is passed into this event will contain the execution, sequence context, and thread object.  From the sequence context you can get the IsProcessModel property to see if the sequence that is executing for the sequence context is within the process model sequence file.  If so, then call the ExecutionView Manager method, SetStepOut that sets the execution to suspend again after execution of the current sequence completes. So, for example in C# the code would say
If (e.ctxt.IsProcessModel)
      e.exec.StepOut();
For LabVIEW, see the attached screenshot.
This should fix your issue.
Hope this helps!
Jonathan N.
(4,094 Views)
Hi Jonathan,
thanks for the solution. It worked out the way i expected.
Thanks and Regards,
MadhuSri
(4,076 Views)
Jonathan,
Very nice description of how to do this! From this I was able to implement it using CVI.
For CVI, the registration and callback function would look like this:
errChk( TSUI__ExecutionViewMgrEventsRegOnBreak (gMainWindow.executionViewMgr,
                                                ExecutionViewMgr_OnBreak, NULL, 1, NULL));
HRESULT CVICALLBACK ExecutionViewMgr_OnBreak (CAObjHandle caServerObjHandle,
                                              void *caCallbackData,
                                              TSUIObj_Execution  exec,
                                              TSUIObj_Thread  thrd,
                                              TSUIObj_SequenceContext  ctxt)
   int error = 0;
   ERRORINFO errorInfo = {0, 0, "", "", "", 0, 0};
   ErrMsg errMsg = "";
   VBOOL isProcessModel = VFALSE;
   tsErrChk( TS_SeqContextGetIsProcessModel (ctxt, &errorInfo, &isProcessModel));
   if (isProcessModel)
      tsErrChk( TS_ExecutionStepOut (exec, &errorInfo));
Error:;
   DisplayError(error, errMsg);
   return S_OK;
} // ExecutionViewMgr_OnBreak
(4,002 Views)
