NI TestStand
missing files?
For some reason my project no longer builds for deployment.
It terminates with the following error:
Starting Analysis
Processing Workspace...
Workspace Processed
Finished Analysis
Building...
3:56 PM
LabVIEW Version: 10.0.1 (2010 SP1) (32-bit) English
The build was aborted because LabVIEW is missing one or more files.  The Deployment Utility is now determining which VIs Reference the missing file(s).
Internal error code 7 Processing VIs...
Could not process LabVIEW VIs. Fix any broken VIs before rebuilding. LabVIEW error:
Invoke Node in Add Item Under Folders By Path - TestStand.vi->Add Top Level Items to Library - TestStand.vi->Make Top Level Library for PPL from Source Dist - TestStand.vi->Make Top Level Library for PPL Using Source Dist - TestStand.vi->PPLBuildClass.lvclass:New Build.vi->Build Distribution - TestStand.vi->Build VI Distribution 2010 (private) - TestStand.vi->Build VI Distribution 2010 - TestStand.vi->Build VI Distribution 2010 - TestStand.vi.ProxyCaller
An installer was not created due to an error
The build is finished
3:57 PM
Aborted
Except the sequence runs fine in the editor & passes analysis.
I have checked that every step .vi is loaded & valid.
Any ideas?
Labview 2010, TestStand 2010
(3,551 Views)
Ah, It appears to only happen if certain options are selected in "Distributed Files" tab "Labview Options" section, including but not limted to "Output VI's to a packaged library"
but i dont understand why...
(3,548 Views)
Hi Hoss183,
Are you running the latest TestStand 2010 patch, this addressed a number of problems with the Deployment Utility. I have included a link to the page where you can download this for your convenience.
TestStand 2010 f1 Patch
Christian Hartshorne
NI|UK
(3,534 Views)
