NI TestStand
multiple numeric limit test
I have a mutiple numeric limit test. I want to modify the measurement set in the test based on my needs. How to access the measurement set property of the test.
when I do the export of the property using the property loader utility, the data is in avery difficult format to read.
Can you suggesst some alternative?
Regards
Gopal
(3,426 Views)
Hi Gopal,
Besides using the Property loader step, you could use an expression to access the measurement set. To do this, right-click on the step and go to Properties>>Expressions, and the measurements are under Step>>Result>>Measurement. I hope this helps. Let me know if you have any questions.
Ebele O.
(3,397 Views)
