NI TestStand
passing large amount of data between steps
in my application, I developed some step types for data acquisition and analysis.
I need to pass large arrays (>100000 points) from one step to another.
Actually I pass the sequence context, and I use Variants to retrieve data (in the second step).
This method seems however quite slow.
Has anyone any suggestion?
I use TS3.5 and CVI 8.0
Thank you
baloss
(3,323 Views)
You should be able to pass the data back directly via the parameter list of the function and like wise directly into the next function without having to use the sequence context.
Regards
Ray Farmer
Regards
Ray Farmer
(3,320 Views)
Hello Ray,
thank you for your quick answer!
I will modify my code according your suggestion and I will let you know.
Regards
baloss
(3,316 Views)
