Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to "Run Test UUTs" from ParallelSeq?
OnlyOne
Active Participant
06-19-2007
09:16 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
i´m starting a parallel-sequence in Seq-file load in the model when starting TestStand. How can i execute a "Run Test UUTs (F5)" from wthis parallelsequence to run the currrently loaded sequence?
Thx
Regards
0
Kudos
Message
1
of 2
(3,156 Views)
Reply
Re: How to "Run Test UUTs" from ParallelSeq?
Wolfgang_Z.
NI Employee (retired)
06-21-2007
07:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I don't understand your problem. Could you explain it a bit more detailed?
Could you post your sequence file?
Thanks and regards,
Wolfgang Z
1
Kudo
Message
2
of 2
(3,138 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
