How to "Run Test UUTs" from ParallelSeq?
i´m starting a parallel-sequence in Seq-file load in the model when starting TestStand. How can i execute a "Run Test UUTs (F5)" from wthis parallelsequence to run the currrently loaded sequence?
Thx
Regards
(2,990 Views)
I don't understand your problem. Could you explain it a bit more detailed?
Could you post your sequence file?
Thanks and regards,
Wolfgang Z
(2,972 Views)
