NI TestStand
namespce TS?
when i build the vc project in teststand example, something is error.
it display something is not the member of namespace TS. I want to know why?
The project is in ...\teststand\example\Operatorinterface\simpleMFC.
if you know the cause ,please inform to me. Thanks a lot!
(3,145 Views)
What version of VC do you use? If you're using VC6 make sure you have service pack 3 or higher installed.
(3,141 Views)
What error are you getting? If you are using VC++ 6.0, you might want to see the following Knowledge Base Entry.
http://digital.ni.com/public.nsf/websearch/EFA211015C99F8F486256DBF00729E4C?OpenDocument
Thank you
Nandini Subramaniam
Applications Engineering
(3,129 Views)
