Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Session Manager Error
James Ormiston
Member
06-10-2005
06:06 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
When executing the function SM_IInstrSessionMgrGetNames I'm getting the following error code returned:
-2147352567
The entry within the NISessionMgr.ini file appears to be correct and the prefix that I'm passing matches the one within the ini file.
Any ideas?
0
Kudos
Message
1
of 3
(3,397 Views)
Reply
Re: Session Manager Error
AllenP
NI Employee (retired)
06-23-2005
10:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Do you have an example that will cause this problem? The error message is a generic "Exception Occurred".
I tried to reproduce the behavior by calling this function in CVI, but everything seemed to work fine for me.
Allen P.
NI
0
Kudos
Message
2
of 3
(3,351 Views)
Reply
James Ormiston
Member
Author
06-24-2005
05:17 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Allen,
Since I created this posted we have been able to solve the problem. To do so we installed the IVI components from the Drivers CD.
Cheers
James.
0
Kudos
Message
3
of 3
(3,340 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
