NI TestStand
Session Manager Error
When executing the function SM_IInstrSessionMgrGetNames I'm getting the following error code returned:
-2147352567
The entry within the NISessionMgr.ini file appears to be correct and the prefix that I'm passing matches the one within the ini file.
Any ideas?
(3,352 Views)
Do you have an example that will cause this problem? The error message is a generic "Exception Occurred".
I tried to reproduce the behavior by calling this function in CVI, but everything seemed to work fine for me.
Allen P.
NI
(3,306 Views)
Allen,
Since I created this posted we have been able to solve the problem. To do so we installed the IVI components from the Drivers CD.
Cheers
James.
(3,295 Views)
