not succeeding in reading StationGlobals
Hi
I'm not succeeding in reading StationGlobals.
What I'm doing wrong?
I'm using 2017 trial
regards,
Koen.
Capture.jpg how I read
Capture2.jpg definition stationgobals
No Error. COMPortMaster stays empty ""
Q2Node returns 0 i.s.o. 70
(2,285 Views)
Accepted by kdCMC
The code you have is correct and I have used that same sequence in other VIs without any issues at least on TestStand 2014.
I noticed that if you create the StationGlobal in the 'Variable View' of the sequence as you showed, you must also go to the View -> StationGlobals entry and SAVE the 'Globals'.  If you don't save it, I got the same '0' result on a test that I did.  Although I also had an error saying the LookupString was 'invalid' , which makes sense because I had not saved it yet.
Did it return any errors or was the value just zero?
~Teds
(2,267 Views)
