NI TestStand
passing an object reference from a sequence to another
hello,
from the Test Stand Editor,
I would like passing object reference of MyClass type from the MainSequence to another sequence.
where MyClass is a type coming from a external dll.
More precisely:
- Start main sequence:
- step 1: create a step action (C# adapter) which is create an instance of a class (type MyClass) coming from an external dll (I know to do it)
- step 2: call secondary sequence with a parameter which is a reference to an object of MyClass type
is it possible ?
(3,686 Views)
this link should help you.
I am assuming you know how to setup a Parameter in you Sequence.
Regards
Ray Farmer
Regards
Ray Farmer
(3,684 Views)
Yes just add an Object Reference variable to the Parameters section of the variables of the sequence you want to pass the parameter to. Then when you specify a sequence call, pass the local variable in which you stored your class reference.
-Doug
(3,669 Views)
Thank you very much, it works
(3,665 Views)
