NI TestStand
How do I deploy the Database Options on a Second station
Hi:
I'm tring to setup a second development station and I can't figure out how to install my custom database schemas.  I tried copying over the file below but it didn't work.
C:\Program Files\National Instruments\TestStand 4.2.1\Components\Models\TestStandModels\Database\TestStandDatabaseOptionsDef.ini
Are the  values set in the "Schema","Statement" and "Column parameters" saved in this file?
If so, why isn't copying the file working?
(3,468 Views)
One thing that may be important.  The source station has TestStand 4.2.1, and the destination station has 4.2.
(3,465 Views)
Accepted by topic author mike_22
You can export and import database schemas using the save and load buttons in the dialog:
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,446 Views)
