This widget could not be displayed.
NI TestStand
passing teststand sequence context to labview
hi,
i want to access teststand sequence context from labview , can i know how to do that ?
-giri
Message 1 of 8
(8,842 Views)
Here is a small example.
Regards
Ray Farmer
Message 2 of 8
(8,841 Views)
This is cross posted here: http://forums.ni.com/t5/LabVIEW/mapping-labview-variables-to-teststand-sequence-context/td-p/1928835
There is another method:
Rodéric L
Certified LabVIEW Architect
Message 3 of 8
(8,837 Views)
Hm! this seems to be a very similar post from giri2309 as a previous post.
Giri2309, I am guessing this isn't going to answer your question so can you expand on what you are trying to achieve?
Regards
Ray Farmer
Message 4 of 8
(8,833 Views)
thanks
Roderic and Ray
Ray u're right in guessing so , but i think i can do rest of the thingsnow. I'll try doing it and if i couldn't then i'll get back to you.
-giri
Message 5 of 8
(8,828 Views)
not a problem,  good luck
Regards
Ray Farmer
Message 6 of 8
(8,826 Views)
I have  noticed in the last few versions of labview that the teststand "sequence context" control is under a "legacy" palette.  Is there a new preferred way of passing sequence context from teststand to labview, other than the standard "sequence context" method?
Message 7 of 8
(8,535 Views)
Thanks for this, was trying hard to figure out what value to put in the test stand Parameter Name to pass the sequence context to the VI.
Turns out all I needed to put in there was "ThisContext". I still have no idea where this information can be found in documentation.
Message 8 of 8
(4,025 Views)
