programatically adding a sequence callback to a sequence file
How do I programmatically add sequence callbacks to a main sequence ?  For example, at setup I get an array that tells me which sequence files to run for each test instance.  I want to call those sequence files as a sequence callback in the main sequence.  I don't want to use the flow control as there is a large number of sequences for this ATE, and the test list can grow in the future.
Shari Chen
Symmetricom
(3,467 Views)
You could take a look at
<TestStand x.x>\Examples\SequenceBuilderTool
<TestStand x.x>\Examples\SequenceFileTranslators
cc
(3,457 Views)
Accepted by top cat
Thanks 🙂 After posting themsg I did find Sequence builder tool, and it was exactly what I was looking for!
Thanks again....Smiley Happy
(3,440 Views)
