NI TestStand
programmatically edit search directories
I would like to know if there is any way using TestStand API to programmatically do the following:
- Get the path value of the entire search directories
- Get the path value of selected index of the search directories
- Insert/Add a new search directory
- Remove one search directory
Thanks for your help and have a nice day
(1,033 Views)
Check the attached example.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(989 Views)
