NI TestStand
"Teststand engine uninstall"
How can I uninstall the teststand engine, on a pc where I installed the engine with the Engine Install wizzard.
There is no uninstall option available.
(4,353 Views)
Ttb,
You should be able to use the Windows Control Panel to remove the TestStand Engine. Just go to Start&#0187Settings&#0187Control Panel&#0187Add or Remove Programs. The TestStand Runtime Engine should appear in the list of installed programs. Simply click the Change/Remove button to remove the TestStand Engine.
Hope that helps!
Shannon R.
(4,353 Views)
Hello Shannon,
The problem is that the Teststand Runtime engine does not appear in the list of installed programs (XP Home edition)
(4,353 Views)
Sometime ago, I thought that I had the same problem.
But the real problem was, that the entry for the Labview runtime in that list was a little bit hosed: The entry included lots of empty lines. So it seemed to be the last entry in the list for the first glance.
But with the second glance, you could scroll down to the next entries ( inluding the Teststand runtime)
(4,353 Views)
This is an old thread so I hope someone is going to see this.
I can't uninstall Teststand either.  It doesn't appear in my "Add Remove Programs" list, and there isn't any blank entries like the previous comment suggests.
I need to install the sequence editor.  Can anyone help?
(3,986 Views)
It should be listed under "National Instruments Software".
(3,980 Views)
