NI TestStand
Backward compatibility for TestStand
Hello all
I have a clarification in using Test Executive code in TestStand.
I am using TestStand for modifying the code which is in Test Executive platform.
Is it possible for me to use modified TestStand code back in Test Executive?
Thanks and regards
Bala
(4,457 Views)
I doubt it.
Regards
Ray Farmer
Regards
Ray Farmer
(4,446 Views)
Thanks Ray
Regards
Bala
(4,441 Views)
TestStand has a tool to load Test Executive sequence files and convert them into TestStand sequences.  However, no tool for making the opposite conversion exists.  As far as I am aware, NI does not anticipate anyone wanting to go from TestStand back into Test Executive.
Josh W.
Certified TestStand Architect
Formerly blue
(4,421 Views)
NI wont anticipate because there are a lot of business aspects associated with it. Smiley Wink
You need to sell your latest product always... Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(4,411 Views)
There is not downward conversion for converting TestStand sequence files to Test Executive code. I believe you would have modify your code in LabVIEW/CVI to still use it.
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(4,386 Views)
