NI TestStand
skipped step should not show in result
I dont want to show the skipped step in the result. How can this happen.
i use teststand4 and expand.xsl style sheet
can anyone help in this regard.
Message 1 of 9
(4,544 Views)
hi
What do you mean exactly?
Disable the skip step s in report?
you have to put "Result.Status != "Skipped" in the filtered expression report options
Cdt
Kamal
Datus Rhônes Alpes
Message 2 of 9
(4,535 Views)
 yes you are right i don't want to show the step which has been skipped in the report. but the solution given by you works for HTML and text report. It doesn't work for XML format. So i was looking for an alternate way to solve it when XML report is used.
Message 3 of 9
(4,527 Views)
Hi
Yes i have testsed and unfortunately it doesn't work for XML reports.
I Have tested to add the engine callback  SequenceFilePostResultListEntry. This callvack has a parameters which is a boolean DiscardResult.
With this parameter we can discard the result list of the Step.
Look at my example attached...
Kamel
Datus Rhônes Alpes
Message 4 of 9
(4,502 Views)
   Does that resolve your issue?
Message 5 of 9
(4,462 Views)
not yet, still working on, partly solved. I was able to trap  the array in which the results were stored and i am trying to delete the elements which contain the status as "Skipped". I was trying to dynamically create an array od the same type and store results into that array skipping the " skipped" elements and later move them back to the results array. But i did not suceed. i am still working on that.
Message 6 of 9
(4,459 Views)
hi,
I don't understand what is wrong with my solution...
Kamal
Message 7 of 9
(4,444 Views)
in your example i need to keep that callback in every sequence which i dont want to do it. I am looking for a place where once the logic implemented it should work every where.
Message 8 of 9
(4,423 Views)
You can modify your process model to have that callback available for each sequence you execute with it.
In order to do this, you have to open the process model and include/modify the ProcessModelPostResultListEntry callback.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 9 of 9
(4,391 Views)
