NI TestStand
"labview reported an error. see 'labview : ' message for more details" NO ERRORCODE
I want to start a TestStand 4.0 Sequence File. But it returns the error message "labview reported an error. see 'labview : ' message for more details" without an errorcode. Dose anyone have an answer to that ?
(4,312 Views)
How was you trying to run this sequence/sequence file, in a UI or SeqEditor.
What version of labview are you using.
Is you code modules using VI's or DLL created from VI's
Regards
Ray Farmer
(4,307 Views)
I started in the SeqEditor.
The Lab View version is 8.6.
I use the Vi's.
Regards
Gerhard Landgraf
(4,303 Views)
Gerhard -
Could you post the set of files you're using so that we can try to reproduce this behavior?
Manooch H.
(4,256 Views)
Hi, I have installed the whole SW again. Now it is working without an error.
Thanks a lot.
Landgraf Gerhard
(4,224 Views)
