Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
read first line of an textfile
stefan.boelster
li
01-18-2005
04:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
i wanna read the first line of a textfile. The textfile only contains one line wit an id like 00017H5.
How can i import these id in my Result?
Sincerely Stefan Bölsterli
0
Kudos
Message
1
of 4
(3,447 Views)
Reply
Re: read first line of an textfile
SAS
01-18-2005
04:53 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you can write a simple LV vi to read the text file. You can pass the file path to the LV vi which can read and gives the data out as string. You can save the data into any container which you use for your report creation.
Sasi
0
Kudos
Message
2
of 4
(3,442 Views)
Reply
Sergei
01-18-2005
05:22 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi, Also, you have a possibility to use the 'File System Object' without a source code.
The example is attached. Hope this helps you. Br,Sergei
"Only a life lived in the service to others is worth living..." - Albert Einstein
File System Object.zip 6 KB
1
Kudo
Message
3
of 4
(3,439 Views)
Reply
stefan.boelster
li
Author
01-18-2005
06:42 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
the FileObj is really a good thing. Now it works fine, and i put the read id with modifiReportHeader below my header.
Thanks Stefan Bölsterli
0
Kudos
Message
4
of 4
(3,431 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
