NI TestStand
regular expressions
is there any possibility to check a character output of a *.vi against a regular expression in TestStand? For example a serial number or a software version number.
*.vi output: M001 matches  {M}00[1-9]
There is a build in step type "String Value Test", but this step type allows only checking against a fixed string and not a regular expression. It might be possible to create a customer step type or adapt the "String Value Test",  whereas  creating my own customer step type seems to be a better solution. Indeed I do not know how to build a step type which fullfills the obove mentioned demands. So any help to this problem is appreciated.
Thanks a lot in advance
Nicole
(3,464 Views)
The idea sounds like a good addition to TestStand 3.5. You might create the test step as a pass/fail and then write a vi that uses regular expressions to check the result of the other vi.
(3,457 Views)
You can enter suggestions for features in new versions of TestStand or any other NI product through the Product Suggestion Center on ni.com.
(3,451 Views)
Thanks to both of you. I solved it the way suggested and posted it as a "convenient-to-have-feature".
(3,448 Views)
