NI TestStand
teststand report and reciept printer
We are using a reciept printer for production test of product.
Reciept printers use a roll of paper.  Page length can be any length.
Teststand insists on sending form feeds at regular intervals, no matter what I set in the printer driver.
In this case, a formfeed advances the paper, and cuts it with a built in cutter.
Thats right, long test results end up in several pieces.
While we can just turn off the cutter, a better way would be to modify the report, preferrably in the XLS style sheet.
Any hints or suggestions?
Jeff
(2,892 Views)
Hi I have a couple of questions. 1. What version of TestStand are you using? 2. What is the report format you are using? 3. How are you printing the report ? using the print button or printing the report from some other application? Anand Jain National Instruments.
(2,880 Views)
