NI TestStand
remove "Begin Sequence" and other strings from text report
I want to remove the string "Begin sequence", "End sequence" and the pathname of the sequence from my text reports that is generated with 'On The Fly Generation' option set, without this option those strings are not present.
I see that strings are inserted by the 'ProcessOTFStepResult' sub-sequence in the report_txt.seq file, this is an activex call that compile the body of the report.
Thank you in advance,
Massimo Ponte.
(3,480 Views)
I suggest you take a look at the following documents to have a more clear view of what teststand offers when it comes to customizing Reports:
https://www.ni.com/en/support/documentation/supplemental/06/report-generation-explained.html
http://digital.ni.com/public.nsf/websearch/05F43468942BE32E86256D980074E200?OpenDocument
AlessioD
(3,471 Views)
