NI TestStand
repeat a test
Is there a way to repeat a test and only report the Pass/fail criteria of the las test run??  I want to run a test where I display a VI from LV in Teststand ( able to do this now).  The operator choses one of 2 buttons ( LED is ILLUMINATED or NOT ILLUMINATED) .  What happens if they hit the wrong button??  I want to have something like a confirmation stick up where it tells them the button they hit and was it the one they intended.  Something like in Windows when you delete something.  It asks if you're sure you want to delete it.  Only I want to confirm they hit "ILLUMINATED or NOT ILLUMINATED" and it was the intended one.  If not, repeat the test and report the reults of that 2nd test ( pass or fail).  If so then just cont w the seq.
Clint
(3,678 Views)
Hi Clint,
I would use for the confirmation the MessageBox-Step-Tpye
If confirmation was bad i would jump back and delete the last ResultList
entry and do it once more.
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,663 Views)
Accepted by Clint Eastwood
Juergen,
BEAUTIFUL!!!!
Clint
(3,658 Views)
