NI TestStand
report options callback
This issue has been discussed in various threads before. However i'm still not able to get it to work properly.
I have attached a simple sequence containing one step, and a report options callback.
I only get a report named ".xml". The dynamic name is missing.
Can anyone "fix" the settings in the report options callback, to add any dynamic name (e.g. $UUT).
thanks
(5,503 Views)
Are you trying to generate a new report for every serial number that is entered or just a final report? Because I am assuming that when a report is generated in this sequence every time it comes out with the same name and this overwrites the previous report.
The report I am seeing generated is ").xml" at the moment. I'm just having a look into this to see if I can find something.
Have you tried using on-the-fly report generation?
Luke
(5,470 Views)
in this "simple" example i would like to name the report :
<serialNumber>.xml
that means a specific report for each uut.
My real need is a bit more complex, but right now i can't even get the simple example to work.
(5,464 Views)
My guess, without testing, is that you are writing the wrong ReportFileSequentialModelExpression. There are multiple locations (e.g. Parameters.ModelPlugin.PluginSpecific...).
Also verify that you are configuring TS to use an Expression for definition of the report file name.
Norbert
Norbert
Expert: Geometry
(5,461 Views)
I got a lot of support from NI application Engineer, and after quite a strugle my report options callback is now working.
The lack of precise documentation and the long list of parameters as well as other strange phenomenons made this very difficult.
I think NI has made a simple thing (choosing (in your sequence) where to store a report) very complicated here.
(5,337 Views)
