report text based on test results
I would like to include debug information in the TestStand report.  For example, if test fails, report text = "Try replacing C1."  Is there one expression that would cover all types of tests?  I'm using TestStand 3.5.  Thanks.
(4,986 Views)
Accepted by AT1
One idea is that you could use the step's additional results.  Just put a debug message as one of the ideas and then set the Condition to Step.Results.Status == "Failed".  Then it will only show if the step fails.
Just a thought.
jigg
CTA, CLA
testeract.com
(4,975 Views)
Hi, when I follow your directions to add the conditional text to the test step on failure.  It prints out every time I run the test step in my For Loop - even when the test step passes.  Please advise.
(1,888 Views)
