NI TestStand
reports for 2 DUTs
I have the following problem:
I want to test 2 DUTs with one testcycle. With the first DUT there will be different tests done as with the first DUT. How can I manage it, that there are two reports at the end
regards samuel
(2,982 Views)
Samuel,
you want to test two different DUTs at the same time with the same testing-equippment. both DUTs need different tests and are, apart from the test-equippment, completely independent. therefore you would like the system to generate two completly independent reports (in seperate files) for the two DUTs. is this correct?.
Norbert B.
Ni Germany
Norbert
Expert: Geometry
(2,961 Views)
