Samuel,
you want to test two different DUTs at the same time with the same
testing-equippment. both DUTs need different tests and are, apart from
the test-equippment, completely independent. therefore you would like
the system to generate two completly independent reports (in seperate
files) for the two DUTs. is this correct?.
Norbert B.
Ni Germany
Norbert
Expert: Geometry
