12-05-2019 03:28 AM
Hi, At some pint in time I cant access my results processing function under the Configure tab. I never has issues in the past. All I can speculate that it could have happened after I installed visual studio on that machine. Now all my results is written in folders all over the place. When I click on results processing, I get this error window. Please assist.
Solved! Go to Solution.
12-05-2019
08:10 AM
- last edited on
12-09-2025
10:06 AM
by
Content Cleaner
I believe that the missing icon is installed with the Test Monitor Client. Do you have this installed? If so, I think a missing icon is probably part of a larger installation issue, and I suspect that other files could be missing too. You could try repairing the installation of the Test Monitor Client first to see if that might resolve it.
Cheers,
Ryan
Product Support Engineer
Automated Test Software R&D
