NI TestStand
running steps and sequences at the same time
I need to run some steps and sequence at the same time in my application due to test time restrictions. I am using Teststand 2.0. Colud you please describe me the methodology.
(4,301 Views)
TestStand Supports execution of multiple sequences at the same time. You can use synchronization steps like rendezvous to synchronize both the executions. However I'm not sure if these features are available in TestStand 2.0
(4,298 Views)
I am not very familiar with Teststand. I am using it due to customer request. I came to a point but i cannot go further. I don't know how synchronization works. All i need is a description or a sample to run two steps in a sequence at the same time and to run two sequences at the same time in Teststand 2.0
(4,295 Views)
Check the TestStand Examples Directory. There is Synchronization directory. You will have examples for RendezVous. I'm Using TestStand 4.1 so I'm not sure if its available in TestStand 2.0.
(4,293 Views)
Synchronization Step types came in at version 2 and there should be an example in the  \teststand\examples folder.
Regards
Ray Farmer
Regards
Ray Farmer
(4,283 Views)
I'd also recommend upgrading to a newer version if possible as there have been a lot of improvements since 2.0.
-Doug
(4,276 Views)
