NI TestStand
sequence context
Hi all ,
Is there any difference in execution time from passing a value using wires in Labview (v/s) calling the sequence context and then calling set property ?
kindly let me know .
(4,161 Views)
Accepted by Padugur
Hello Padugur,
please look into this thread:
Sequence Context vs. Parameters
Normally wire are and parameters are faster then setting a value thru a property node.
best regards
Alexander
(4,117 Views)
Its always better to go by passing the output results directly to variables than using sequence context.
(4,107 Views)
