NI TestStand
sequence context
Hi all ,
Is there any difference in execution time from passing a value using wires in Labview (v/s) calling the sequence context and then calling set property ?
kindly let me know .
(4,274 Views)
Accepted by topic author Padugur
Hello Padugur,
please look into this thread:
Sequence Context vs. Parameters
Normally wire are and parameters are faster then setting a value thru a property node.
best regards
Alexander
(4,230 Views)
Its always better to go by passing the output results directly to variables than using sequence context.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,220 Views)
