NI TestStand
shared variable synchronization
I am trying to send data between computers. I have used shared variable to do this and to avoid race condition I have append "?sync=true" in URL to synchronize access to shared data.  But when I run  Send and Read VI, race condition sometimes still appears? Even when I run both VIs on same PC.
I have attached VIs, if someone would like to try it.
andrej
(2,863 Views)
This doesn't sound like a TestStand question more of a LabVIEW question. If so, you need to re-post to the LabVIEW forum.
Regards
Ray Farmer
Regards
Ray Farmer
(2,860 Views)
