NI TestStand
Patch for Teststand if .Net v2 SP1 is NOT installed
I work for a large organisation and I dont think our computers are upgraded to .Net v2.0 SP1 yet.  Should I still install the 4.0.1f1 Patch for Teststand?
Vikas
Message 1 of 8
(4,222 Views)
Vikas
You only need the patch if you have .Net framework SP1 is installed on that machine.
Regards
Anand Jain
Message 2 of 8
(4,212 Views)
Vikas
I would like to add that Microsoft pushed out .Net Framework 2.0 as an critical update around Jan 25th 2008.
So you might already have it installed on your machine if you have 'Windows Updates' enabled.
Regards
Anand Jain
Message 3 of 8
(4,206 Views)
Hi Anand,
Thanks for your reply.  Please could you tell me if .Net 2.0 is same as .Net 2.0 SP1?  I might already have it in that case.  Also, is there any harm in installing the Testand update even without the above version of .Net?
Vikas
Message 4 of 8
(4,172 Views)
.Net 2.0 SP1 is the Service Pack for .Net 2.0 (similar to Windows OS service packs).
There should be no harm in updating TestStand even if you haven't installed the Service Pack.
KostasB
NI UK
Message Edited by KostasB on 02-18-2008 09:57 AM
Message 5 of 8
(4,149 Views)
Thanks Kostas!
I will update Teststand at the earliest.
Regs,
Vikas
Message 6 of 8
(4,142 Views)
Hi Vikas
I would not update TestStand if there is no need to,  i.e. if you did not install the service pack for .Net 2.0.
It is a new patch and although there should be no problems, it is often that customers unveil bugs that we failed to identify during our testing period.
KostasB
Message 7 of 8
(4,084 Views)
Hi Kostas,
Thanks for letting me know. I downloaded the update but have not patched it yet. Will put it off until need be.
Regs,
Vikas
Message 8 of 8
(4,081 Views)
