NI TestStand
soldering on pcs-e68fs for DAQ
I must connect my hardware to the daq through a pcs-e68fs, does anyone know where or if I can find little metal pins where I can solder the cables to and then slide the pins onto the pcs-e68fs connector. If they exist, where can I get them, what are they called or what is their part number? Thanks.
(3,396 Views)
I think that you might get a better response if you post your questions to another group other that TestStand. When you go to www.ni.com/ask and choose to post a message to Dev Exchange, I think you want to select Mulitfunction I/O under Measurement Devices.
I searched for you connector (pcs-e68fs) on ni.com and found the follwing link that details the connector and other parts that correspond to your the connector.(http://digital.ni.com/public.nsf/web/lastweek/8ECF4BAD615F18BC8625648400521E97). This is KB article 06MDRGNI
. Perhaps one of them is what you are looking for.
(3,396 Views)
