stationglobals.ini error
Could someone help me with this error (attached) when I tried to open TestStand Sequence editor.
dphan128
(3,443 Views)
Accepted by dphan128
Looks like your Station Globals file was corrupted.  If you have another machine install TS 3.1 and copy the StationGlobals.ini file over to the same path in the error message or contact NI and have them give you a clean Station Globals file.  Or you can just re-install TS on the current machine.
jigg
CTA, CLA
testeract.com
(3,442 Views)
Thank you jigg. It works !
(3,436 Views)
