08-26-2011 11:45 AM
Could someone help me with this error (attached) when I tried to open TestStand Sequence editor.
dphan128
Solved! Go to Solution.
08-26-2011 11:48 AM - edited 08-26-2011 11:48 AM
Looks like your Station Globals file was corrupted. If you have another machine install TS 3.1 and copy the StationGlobals.ini file over to the same path in the error message or contact NI and have them give you a clean Station Globals file. Or you can just re-install TS on the current machine.
08-26-2011 12:05 PM
Thank you jigg. It works !
