NI TestStand
string value test results in default database
Using the default TestStand database, numerical results get stored in the PROP_RESULT.DATA column.
Where do results of string value tests get stored?
(4,048 Views)
I just tested in 2014 and it gets stored in PROP_RESULT.DATA as well.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,041 Views)
Odd. I created a new sequence and a new string test VI, and the PROP_RESULT.DATA database column in my sandbox database gets assigned the returned string. I don't even need to click the 'Log' checkbox in the module tab of the step setting. All I need to do is asign the string value to Step.Result.String.
Found the problem. The database datatype for PROP_RESULT.DATA is a double instead of a varchar. I wonder how that happened...
Stephen
(4,008 Views)
I think I am just going to store the string results in STEP_RESULT.REPORT_TEXT at this point.
To do this I put the following in the step post expression
Step.Result.ReportText = Step.Result.String
(3,990 Views)
