NI TestStand
teststand public directory macro
I would like to get the TestStandPublicDirectory path in an expression using a macro. Is it possible? Or is there any other way to get the path string of the directory?
Madottati
(4,947 Views)
Accepted by Madottati
RunState.Engine.GetTestStandPath(TestStandPath_Public)
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,939 Views)
GetTestStandPath Method
Syntax
Engine.GetTestStandPath ( testStandPath)
Return Value
String
Purpose
Returns the pathname of the TestStand directory the testStandPath parameter specifies.
Remarks
The pathname does not contain a trailing backslash.
Parameters
testStandPath As TestStandPaths
[In] Specifies the TestStand directory to return. Refer to TestStandPaths for more information about TestStand directories.
jigg
CTA, CLA
testeract.com
(4,930 Views)
