10-28-2019 11:14 AM
I modified the horizontal.xsl report file by changing gIndentTables from True to False. Now TS throws an error, (as Titled), when opening the Reports file.
Nothing has changed with line 1. I set TS back to the original horizontal.xsl file and the problem persist.
10-28-2019 02:02 PM
So only during Runtime the Report file is unable to load, but at completion the xml report loads and is viewable from TS Report Tab.
06-16-2020 10:24 AM
Its happening again, On the Fly report says "Unable to load xml report, at line 1 invalid at the top level of the document.
Here's what changed.
Original source code no issues when running.
Source code from revision control I get an error with the "Report on the Fly". A report does display but only when the test has completed.
11-24-2020 09:37 AM
The canned error message
"Unable to load XML Report. At Line 1 invalid at the top level of document"
will flash for a few test steps, then the report appears for 1-2 seconds then the canned message is back again.
Is there any setting that can be changed to ensure the On-the-fly-report is generated, instead of unable to load. Do I need to increase the test PC ram memory? Is this a problem with the TS dll that generates the report? Does the size of the report... opening file, appending file affect TS performance?
