NI TestStand
unexpect "unknown variable name" warning
Hello
i'm using TS2016 and when i copy a number variable in an container to expression, it show "unknown variable or property name" warning but obviously the variable is just locate there.
(3,293 Views)
Accepted by johnnnywang
In your array called 'Steps', you have 2 array elements which are called 'M'. So in your expression, I guess you want to use the second 'M' element which have a "Pol' subproperty.
But I think TestStand use the first one and I suppose that this one don't have any 'Pol' subproperty
Laurent
(3,273 Views)
Thanks, it's duplicated, issue removed after 1st M deleted
(3,239 Views)
