NI TestStand
valid object reference
I have a station global object reference. Is there a way to check if the object reference is valid?
Thanks.
CLD
(5,304 Views)
Accepted by lvrat
StationGlobals.MyRef != Nothing
-Doug
(5,300 Views)
I have a similar issue where I need to know if a session number is still valid before I try to close it.  I have cleanup steps that close references/sessions/handles, etc. in case an error occurs in the sequence, but if no errors occurred, then they should already all be closed.  Would the "!= Nothing" be valid for everything?  Thanks.
GSinMN
(4,978 Views)
Hi GSinMN,
The Nothing constant refers to empty ActiveX references.  You can find more information about it here:
Special Constant Values: http://zone.ni.com/reference/en-XX/help/370052K-01/tsfundamentals/infotopics/special_constant_values...
-Myriam
(4,963 Views)
