NI TestStand
viewing sequence steps
Something has changed in my Teststand set up as I used to see each step in my sequence file as it was being executed in single pass mode
but now it does not display each step.
Is this a setting or some configuration that I need to change in order to see each step as it is being executed in my Seq file?
thanks
(3,919 Views)
Accepted by robojeff
robojeff,
Try Configure > Station Options > Execution tab, and make sure tracing is enabled.
(3,916 Views)
awesome thanks Daniel!
(3,913 Views)
